2000 Dodge Intrepid brake booster is rusting-can't find wat
2000 DODGE INTREPID
LILAC
  • 6 POSTS
Brakes problem
2000 Dodge Intrepid Front Wheel Drive Automatic 19,000 miles
this has been replaced twice & it looks like it's starting to rust again. I lose all braking power, car has to be towed. First time cost was $600, second time cost was $500. Sealant was placed around front windshield, thinking the leaks were coming from there, however it's starting to rust again. Both times of replacement occured in November & water accumulations were in the form of ice. Can't find any recalls from Dodge relating to this problem.
Jul 12, 2010 at 11:19 AM
First, keep in mind, even if you lose power assist, you will still have brakes. You will have to push much harder to make them work.
As far as the rust, is that the actual mileage (19K)? If that is correct, let me know if the car sits in a garage or outside.
Jul 16, 2010 at 11:23 PM
LILAC
  • 6 POSTS
The mileage is correct 20K & the car is kept outside. Seems like water is getting in there & no one know why. New brake booster was replaced in 2008 (november) & 2009 (november), water turned to ice. And maybe the brakes assist should have worked but there were no brakes at all. Thanks for the input so far, hope you can solve this for me & my mechanic.
Jul 23, 2010 at 11:56 AM
When you lost brakes, did the pedal go to the floor?
Jul 24, 2010 at 12:55 AM
LILAC
  • 6 POSTS
Brakes gave away completely, down to the floor. Luckily I was in my parking spot and not on the road. When I went from "park" to "drive" took my foot off the brakes, the car lunged forward, I threw it into "park", it stopped, put the car in "reverse" to put back into the parking spot, it lunged backward and did "reverse" again and the car stopped. Had to have it towed to garage (both times).
Jul 26, 2010 at 8:43 AM
If they went to the floor, it sounds like the master cylender and not the booster. The only thing that the booster would cause is a loss of power assist.
Jul 26, 2010 at 10:32 PM
LILAC
  • 6 POSTS
I have both my bills - 12/10/08 - Midas - replace new p/b brake booster....
my mechanic - 12/18/09 - install brake booster
neither bills mentions brake cylinder
Jul 27, 2010 at 2:30 PM
That doesn't make sense to me. The booster is nothing more than a vacuum chamber that assists when you press the brakes. If it is bad, the brake pedal gets hard to push. If the pedal went to the floor, there is either a leak or bad master cylender.
Jul 28, 2010 at 12:38 AM
LILAC
  • 6 POSTS
The problem is that water is accumulating in the brake booster causing the accumulation to turn to ice which caused loss of brakes. Both occurances happened in November. The second time, caulking was applied around the windshield, thinking the water may be coming from there. As of today, everything is working fine but come November or when we get the first drop in temperature, will this water accumulation turn to ice again? Where is the water coming from? I understand my mechanic's friend at the local Dodge dealership doesn't know the answer either.
Jul 29, 2010 at 9:30 AM
After 30 years, I don't say this often, but I'm at a loss. There is vacuum from the engine, so water can't be coming from there. The booster is sealed, so there shouldn't be any leaks that would allow water to get into it.
Jul 30, 2010 at 12:27 AM
LILAC
  • 6 POSTS
Welcome to the "head scratchers club". All I can do is wait for the other shoe to fall in November, see what happens, if I'm going to have the same $500/600 problem again.
Thanks, once again.
Jul 30, 2010 at 9:39 AM
Thanks. You have me stumped on this. I wish I could have been more help.
Jul 30, 2010 at 11:34 PM
