2000 Dodge Intrepid
2000 DODGE INTREPID
215,000 MILES • 6 CYL • FWD • AUTOMATIC
SILVIAAZ04
Car hit dip in road, last oil change they put an oil filter that is a bit longer than skid plate. Oil filter was damaged did not know 5 miles down the road engine stopped. Low pressure warning light came on only for a minute. All oil had leaked out, replaced oil it will not start something is turning when you the key but thats it. Is there a safety fuel shut off switch or something? Or is engine toasted.
Feb 11, 2010 at 1:59 PM
If someone other than you did the oil change, they are responsible for damages. As far as the engine, if it turns over, there is a good chance it is okay. If it doesn't start, check to see if there is spark and fuel getting to the engine. Here are the how to's for checking.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Feb 13, 2010 at 8:01 PM
SILVIAAZ04
Thank You for your help I will get back to you on the results.
Feb 15, 2010 at 8:13 AM
