1999 Dodge Intrepid wiring harness
1999 DODGE INTREPID
68,000 MILES • 6 CYL • 2WD • AUTOMATIC
SCARLETROSE68
trying to figure out how to install a wiring harness from a 2001 intrepid engine into a 1999 intrepid. What are the differences on the harnesses? Which way would be easier- modifying the 2001 harnass to the 99 or modifying the 99 to the 01 engine. any information or diagrams would be great. thanks
Mar 16, 2008 at 2:14 AM
MERLIN2021
  • 17,250 POSTS
If I understand you right, you put a 2001 engine in a 1999? If the plugs don't match, you may also need to replace the PCM..Check with Dodge service. If the wire colors are the same, you might be able to change the connectors, by removing the locks, and changing the ends over...
Mar 16, 2008 at 8:43 AM
SCARLETROSE68
just wanted to say thanks. im trying to help my hubby out...hence why i sound very uneducated in this matter. thank you again for geting back so quickly; hubby is pulling his hair out! :?
Mar 16, 2008 at 5:04 PM
