Engine Mechanical problem
1999 Dodge Intrepid 6 cyl Automatic
I was wondering if anyone ever got a answer to the no compression problem after rebuilding the 2.7? I also just rebuilt the 2.7 and made sure #1 cylinder was TDC and set all timming marks up with chain marks(doubled checked) When I went to start it acted like it had no fire! after spending hours trying to troubleshoot it, I decided to check compression in cylinders and found I had no compression anywhere! I seen this guy on here had the same problem to but I never seen anyone come up with a solution! Is there anyone in here that has any ideas what could be causing this? thank you!
Apr 12, 2009 at 11:32 PM
