1999 Dodge Intrepid Failed Transmission?
1999 DODGE INTREPID
116,000 MILES • 6 CYL • FWD • AUTOMATIC
BRYANTSEL
  • 18 POSTS
Hey,
I have a 99 Dodge Intrepid and I am having a big issue. I was driving and the car made a grinding/screeching sound and started spraying transmission fluid everywhere and then coasted to a parking spot. I checked the transmission fluid and there is none. When I put the car into reverse it will reverse fine, however, when I put the car into drive it will not move. I will have it towed somewhere, but from what I have described would anyone have any ideas what happened?
Thanks,
Jun 17, 2008 at 6:06 PM
BMRFIXIT
  • 19,053 POSTS
I have seen it where a pin inside the transaxel will come loose and shave in the tranny housing causing it brake and leak the fluids
you should have it towed and check
Jun 17, 2008 at 8:35 PM
