my check engine light is on says bank 2 cat. Once in a while right after start will idle rough and try to die. today it was running so rough after start and it did die it was hard to keep running but would start, sounded like it wanted to backfire, if i took foot off gas would die. finaly giving it light gas for awhile got it running went to store got another diag check still said cat he said somthing about cat bank two. well my problem is that he accidently erased the code, I want to fix this but which is bank two? plus i'm worried i had a malibu that did this soon before i was told that my cam was flat in it. is this somthing that would happen from not replacing the cat or will things like that cause a cat code to fire even thoe that is not the problem. i just dont want to put toomuch into it next i need to move on to the suspension.
Feb 19, 2010 at 10:40 PM
