[quote:9e9b281e9f="Jacobandnickolas"]You need to remove the plenum to access that area. Please keep in mind, any fuel leak is dangerous. Also, chances are it isn't the fuel rail but an injector or rubber hose.[/quote:9e9b281e9f]
I actually pulled out the cross support [between strut towers] found the plastic high pressure in line cracked,dealer says line from tank to rail, but looking at repair kits but only listed to 2007,you'd think u could cut n stick some hi press line in place of the plastic?
Jul 17, 2010 at 8:51 PM
