1998 Dodge Intrepid Battery Draw with ign off /key out
1998 DODGE INTREPID
275,000 MILES • 6 CYL • FWD • AUTOMATIC
JAMES PACHLA
MEMBER
FOLLOW
Battery goes dead overnight, I did a draw test, test light stays lit with all fuses removed. What next
Oct 27, 2009 at 5:17 PM
MHPAUTOS
CERTIFIED EXPERT
Hi there check with an Amp meter to get the exact draw, also make sure that you check with any fusible links off and also the alternator as a faulty diode will feed back voltage and still give a reasonable charge rate, check this next.
