1997 Dodge Intrepid Won't run
1997 DODGE INTREPID
100,000 MILES • V8 • FWD • AUTOMATIC
WMCOUP
Kid's car stopped two weeks ago. The car would sputter and then stop. Had it towed to garage. Fuel Pump OK, code reads cam sensor - they replaced & now it doesn't run at all. Then they replaced the computer (they one the installed is one number off from the original). Mechanic is out of ideas - need to have it retowed. Any suggestion as to the problem would be appreciated since my kid is in college and he's using MY car in the downtime.
HELP
Jan 11, 2008 at 7:40 PM
BMRFIXIT
  • 19,053 POSTS
[quote:b06ec59dbf="wmcoup"]Engine problem
1997 Dodge Intrepid V8 Front Wheel Drive Automatic 100000 miles
HELP[/quote:b06ec59dbf]
for it not to run it must be missing something do they know what is it that missing
u said fuel pump OK we re going to say you have fuel pressure
what about spark ?
did they check crank sensor
timing belt
ASD relay
Jan 11, 2008 at 7:59 PM
WMCOUP
Yes, it has spark and the timing belt is working but should be replaced they advised. They replaced the cam sensor an one other sensor in that area I'm told, it may have be a crank sensor. What's an ASD relay?
Jan 11, 2008 at 8:18 PM
BMRFIXIT
  • 19,053 POSTS
[quote:79ed6cd6c4="wmcoup"]Yes, it has spark and the timing belt is working but should be replaced they advised. They replaced the cam sensor an one other sensor in that area I'm told, it may have be a crank sensor. What's an ASD relay?[/quote:79ed6cd6c4]
ASD auto shut down relay its under hood relay /fuse box
you have spark and you have fuel pressure do you have injector pulse
what is the TPS volts or angle degree
also how’s the spark plugs looking
Jan 11, 2008 at 8:29 PM
