1 Motor Mount: Loose or broken motor mount.
2 Exhaust System: Damaged or restricted exhaust system components.
3 CV Halfshaft: Dry,Worn or damaged cv half-shaft
4 Tie Rod Adjusting Sleeve: Improperly aligned adjusting sleeve or other steering component.
5 Transmission Mount: Loose or broken transmission mount.
6 Tie Rod End: Loose, worn or incorrectly adjusted tie rod end(s).
7 Steering Stabilizer Mount Kit: Loose or broken steering stabilizer bracket
8 Pitman Arm: Worn pitman arm or other front end part(s).
9 Idler Arm: Worn idler arm or other front end part(s).
10 Ball Joint - Lower: Worn or damaged lower ball joints
11 Ball Joint - Upper: Worn or damaged upper ball joints.
Dec 23, 2008 at 9:19 PM
