1996 Dodge Intrepid trouble codes
1996 DODGE INTREPID
OKVEL
Computer problem
1996 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
code 12 and code 66 ?
Thank you!
Aug 30, 2008 at 12:25 PM
OLDTECH2
  • 64 POSTS
Code 12 is a battery connection issue. The battery has been disconnected in the last 50 startups.
Code 66 is the pcm not recieving the ccd bus signals. Do you have any other codes?
Both of these sound like a loss of battery voltage to the car. The other option would be a drop in voltage like the alternator quit. If the voltage gets to around 10.5 volts, the electronics quit working. The pcm is generally the last to stop working.
Aug 30, 2008 at 7:59 PM
