Engine Performance problem
1996 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
WHEN ENGINE SITS OVERNIGHT,CAR STARTS AND QUITS A DOZEN TIMES BEFORE IT STAYS RUNNING.
CHECKED FUEL PRESSURE,45 LBS AND DOES NOT DROP WHEN CAR STALLS. CHECKED CRANK AND CAM
SIGNALS,DOES NOT DROP OUT. REPLACED CRANK SENSOR JUST BECAUSE. NO CODES STORED,ECT AND MAP SENSOR READING CORRECTLY. I CAN COMMAND RPM UP AND DOWN WITH SNAP ON SCANNER,SO I KNOW IAC IS WORKING. DONT KNOW WHERE TO GO FRM HERE. ANY HELP IS APPRECIATED. THANKS.
Jun 7, 2010 at 11:11 AM
