1996 Dodge Intrepid Engine Missing
1996 DODGE INTREPID
168,000 MILES • 6 CYL • FWD • AUTOMATIC
GULFWARDOC
3.5 engine missing acting like running out of gas stutters, changed timing belt, water pump, fuel filter, double checked timing belt after 2 days, checked for leaking compression none, checked for leaking intake gasket None, no check engine light and no codes, checked fuel pressure Good
Nov 16, 2008 at 9:16 PM
ZACKMAN
  • 4,202 POSTS
Any vacuum leak anywhere? About leaky EGR valve?
Nov 17, 2008 at 12:34 AM
RACEFAN966
  • 5,029 POSTS
Does this car have a mass air flow unit? If so have you cleaned it? You can only clean it with mass air flow cleaner you might want to try this.
Nov 19, 2008 at 9:26 PM
ZACKMAN
  • 4,202 POSTS
Does not have MAF sensor.
Nov 20, 2008 at 1:06 AM
