Coolant temp sensor issue or air pocket?
1996 DODGE INTREPID
REGAN 4435
The car will spike the temp gauge, then go back to normal. Does it with no rhyme or reason. should I replace t stat? if so how do I go about that?
Apr 21, 2009 at 11:09 AM
This could be a couple things. It could be a temperature sensor, an air pocket that is moving through the system, or the thermostat.
If it were me, I monitor the voltage on the sensor and make sure it is moving in relation to the gauge. If it is then monitor the temperature on the thermostat housing using a laser temperature gauge and see if the temperature is actually doing this.
https://www.2carpros.com/articles/symptoms-of-a-bad-coolant-temperature-sensor
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
https://www.2carpros.com/articles/how-to-use-an-infrared-temperature-meter
If it is then you have a thermostat that is opening and closing which means you need to remove it and put it in a pot of water and boil it and see if it is opening properly and staying open.
I attached the info below as I suspect this is a sensor issue. Please let us know if you have other questions and what you find. Thanks
Jul 14, 2021 at 6:17 PM
