1995 Dodge Intrepid Turn Signals and Hazard Lights
1995 DODGE INTREPID
137,000 MILES • 6 CYL • FWD • AUTOMATIC
CASIOPIA
None of my turn signals or hazard lights work. I've checked the fuses and they look good. I visually checked all bulbs and turned on the parking lights to ensure bulbs operate and are not the problem. I bought a brand new multi-function (turn signal/wiper/high beam) swith and installed it to no avail. A little history...About a year ago everything worked. Then I remember trying to use the hazards and I heard kind of like a buzzing or sizzling sound when I depressed the hazard lights switch (which is part of the multi function switch). That is when the problem started. Could it be a problem with the wiring connector that plugs into the multi-function switch? Thanks for your help.
Apr 6, 2008 at 5:28 PM
2CARPRO JACK
  • 11,533 POSTS
There is a combo flasher under the dash to the right of the steering column, works both turn signals and the hazards. I would go to that if you have replaced the switch assembly and it didnt fix it.Red/White wire should be power,Pink flashes with t-signals and DK Blue/ Pink is the hazards
Apr 7, 2008 at 7:54 AM
