1995 Dodge Intrepid The Power windows
1995 DODGE INTREPID
JMW123
Interior problem
1995 Dodge Intrepid 6 cyl Automatic
After I disconnected the battery the power windows will not got down at all. Is there a switch I need to look at or reset?
May 6, 2009 at 9:47 AM
JDL
  • 16,098 POSTS
Hello, check the power window circuit breaker in fuse block. Use a testlite where the breaker plugs in, the circuit should go hot when you turn the key on.
There may be multiple circuit breakers for different systems, if they have the same amp rating, you can swap them out, for testing.
May 6, 2009 at 10:11 AM
