1995 Dodge Intrepid Air Intake
1995 DODGE INTREPID
130,000 MILES • 6 CYL • FWD • AUTOMATIC
DMVC4
Hi, I drive a 1995 Dodge Intrepid with a 3.3L V6. I will be installing an aftermarket cold air intake system and was wondering if anyone could tell me what this certain component is. Right now the car has the stock intake and filter. The intake tube runs from the filter into this "device" and then into the engine. It looks like it's an air splitter, a small hose branches off from this point to a separate engine component. I took off the part and looked inside. Inside there seems to be a stationary core with fins attached. Does anyone have any idea what this thing does and is it safe to remove before I put on an aftermarket cold air intake?[img:ffe0194529]http://www.2carpros.com/forum/automotive_pictures/335204_Intrepid_1.jpg[/img:ffe0194529]
Mar 23, 2009 at 11:18 AM
JESSIEMARIUS
  • 4 POSTS
Sounds like the Mass Air flow sensor. I don't think it should be taken off because it can cause your car to "throw codes". This sensor is usually in line with you air filter.
Mar 24, 2009 at 6:00 PM
CARADIODOC
  • 34,306 POSTS
Please leave this alone. Manufacturers spend a lot of time figuring out the best way to warm up the air going into the engine for better fuel vaporization and better engine performance. The only reasons to cool the air are to reduce the excessive heating effects of a turbo charger or to pack more air into the engine. Cold air is more dense.
Once more air enters the engine, there won't be enough fuel to go with it so you will constantly have a lean condition. The oxygen sensor will report that to the engine computer which will try to richen the mixture and reduce idle speed back to normal. The computer can only adjust fuel metering plus or minus 10 percent. If that isn't enough to get enough fuel in to match the air flow, you'll have to find larger aftermarket injectors. With more air and more fuel, guess what happens to idle speed? The computer controls that too by turning the injectors on for shorter periods of time and by blocking or opening an air passage around the throttle blade. Once the computer is done updating the fuel trims in its memory, the result hopefully will be the correct amount of fuel to go with the amount of incoming air which, . . . wait a minute, . . . that's what you have now!
Every time you turn the ignition switch on, the MAP sensor informs the engine computer of barometric pressure. Higher pressure pushes more air into the engine and the computer is programmed to compensate for that.
Fuel mixture is also modified based on a reading from the ambient air temperature sensor which lives inside the engine computer. It expects the air entering your fancy plumbing to be the same temperature as what's inside the computer. Colder than expected air entering the engine causes a lower percentage of the fuel to vaporize. This results in a lean-running engine with excessive hydrocarbons out the tail pipe. Liquid fuel does not burn; it goes out the exhaust where it can overheat and melt the catalytic converter. If the converter substrate melts, it can plug the exhaust. If that happens, you'll be able to walk home faster than driving!
Chrysler domestic vehicles never use a Mass Air Flow sensor. They are the only manufacturer that has been able to make an engine run good without one. The part you're referring to is a muffler that reduces the annoying drone on the highway caused by the air flow. It has no adverse effect on performance.
The air filter in your picture is a K&N aftermarket unit. There are plenty of things that limit horsepower, but the original air filter isn't one of them.
These cars already will tear your pants off and they get decent fuel mileage. Why risk all the potential damage and performance problems these modifications create?
caradiodoc
Mar 25, 2009 at 4:49 AM
UDRV2SLW
im a mechanic of 15 years or so. That is not a mass air flow, that box is a that collects warm air from the engine to yes help vaporise the fule. BUT a cold air intake is more fule eficent because cold air as to warm air is more dence and make for a bigger bang on the combusting stroke.i have my own 1995 intrepid with 3.3. i use a cold air intake. Recomend to use a pcv filter on the valve cover. do not run that hose back to the intak enenthought most cold air intakes have it. if u hook it bak up u will be defeting the pourpose of the COLD AIR.
Aug 20, 2009 at 8:02 PM
CARADIODOC
  • 34,306 POSTS
Yes, cold air is more dense. So there's no point in having an ambient air temp sensor as it will be reporting incorrect information. The oxygen sensor will see a lean condition, so the computer will request additional fuel. This will affect long term fuel trim values which will no longer be a clue to a driveability expert. The exact same thing can be accomplished by pushing down further on the gas pedal. More air and more fuel in the most precise mixture.
Even though a little more air might enter the cylinders, at top rpm the injectors can't flow any more fuel to achieve a proper mixture because besides injector pulse width, which is the only thing the computer controls, flow is based on nozzle size, barometric pressure, manifold vacuum, and fuel pressure, none of which have been changed. The injectors can not stay on 100 percent of the time. There needs to be at least a small time where the injectors are off so the computer can detect a grounded wire or shorted injector winding. Also, the pintle valve in the injector can only move just so fast. It needs time to physically close before it can be commanded open again. If you look at the current waveform of an injector, you can see the exact point the pintle valve unseats. Some of the more sophisticated engine computers look at the switch point for diagnostics.
All this means is there is a limit to what the injectors can do to keep up to any additional air. No sense messing with what already works well.
Everyone knows engines get better fuel mileage in the summer, not in winter when the air is cold and combustion is not as complete.
caradiodoc
Aug 20, 2009 at 11:08 PM
