1994 Dodge Intrepid Tramsmission stuck in second gear like
1994 DODGE INTREPID
20,000 MILES • 6 CYL • FWD • AUTOMATIC
STANM4
Hi, my name is Stanley our 94 intrepid with a 3.5 automaticly drops in second gear.i scaned it with a 08 Gennisis and it showed a code 36 ,shifting maulfunction, i also looked at the data stream and the imput shaft had rpms in neutrel and the output shaft had rpms while moving. thought it might be the out put speed sensor but the scanner also said could be worn clutch patck what do you think ? Thanks.
Mar 4, 2009 at 7:47 PM
DOCFIXIT
  • 18,828 POSTS
Could be either the input shaft sensor most likely. Fluid look good?Just before it kicks down does engine rev up?
Mar 5, 2009 at 11:23 AM
