Heater Problem, Need Help ASAP!
DODGE DYNASTY
JAS21871
Driving down the road my heater stopped blowing warm air! I checked all the fuses and none were blown. Where is the heater blower located on a 1992 Dodge Dynasty 6cyl.?
Dec 4, 2006 at 4:50 PM
GARFIELD
  • 197 POSTS
You should be able to get to your heater blower motor under the passenger side of the car under the dash. Disconnect the connector from the fan, turn on ignition key to the on position and test the connector for voltage, if there is voltage then the problem will be in the motor. If it has no voltage then it will be in the blower resistor, switch or wiring.
Dec 6, 2006 at 5:18 AM
