1993 Dodge Dynasty passing gear
1993 DODGE DYNASTY
136,860 MILES • 6 CYL • FWD • AUTOMATIC
ROBINSQUEST
the problem I have with my dynasty is it will shift ok but when I get it up to 55 it will not shift and it will run in high gear and will not shift down. You can hear it running high. I used to have to stop, shut it off, wait a few minutes and then restart and it would be ok, but it does it often now and I can only drive it around town. It used to try to lock up on me while driving but has not done that for a while. I hope I explained it right cause it is hard to explain certain things so I hope you can understand me, lol. thanks Robin
Feb 22, 2010 at 2:37 PM
CARADIODOC
  • 34,306 POSTS
The transmission is going into "limp-in" mode. This happens when the transmission computer detects a problem. It will keep it in second gear and record a diagnostic fault code. The transmission computer tells the engine computer there's a problem so the engine computer turns on the Check Engine light.
You'll need a hand-held computer called a scanner to read the fault code(s). As a general rule, if it defaults to second gear right after starting the engine and shifting into drive, suspect a sensor problem. If the transmission starts out in first gear, then stays or goes into second gear right after an upshift, suspect slippage in one of the clutch packs.
caradiodoc
Feb 26, 2010 at 7:52 AM
