1992 dodge has way too fast idle affecting shifting.
1992 DODGE DYNASTY
SALEM JIM
i have a dodge dynasty,,1992,,303,,v6. 105,000 miles, it idles at about 1000 rpm at all times. start up, engine cold or hot. the check engine light comes on and stays on all the time. I replaced the throttle position sensor, but it didn't correct the problem, can you suggest all the areas that may be the culprit? thanks.
salem jim,,,,ohio
Mar 24, 2007 at 6:08 PM
MERLIN2021
  • 17,250 POSTS
if the idle isn't dropping down try pulling the codes...bet you find a bad temp sensor!
Mar 31, 2007 at 10:56 PM
