1991 Dodge Dynasty trouble code 43
1991 DODGE DYNASTY
ALAN DETRICK
  • 4 POSTS
Electrical problem
1991 Dodge Dynasty 6 cyl Front Wheel Drive Automatic 130k miles
code 43 comes up- car dies. code reader shows ignition coil number 3 circuit. ok fine, but what is #3 circuit? i suspect crank senser ? wish these manuals were more compleat. Also does this car have an ign coil moduel? Can't find that info anywhere. Thanks for your help, Alan
Jun 17, 2008 at 11:53 AM
MERLIN2021
  • 17,250 POSTS
I show cylinder misfire, OR coil circuit...What are the symtoms? No start or misfire in the engine?
Jun 17, 2008 at 12:53 PM
ALAN DETRICK
  • 4 POSTS
STARTS FINE COLD BUT WILL JUST UP AND STOP AT IDLE AFTER 5-10 MIN. OR IF DRIVING STARTS TO RUN ROUGH AND THEN DIES. HAS TO SET FOR 30 MIN AND WILL RESTART BUT RUNS ERARTIC. SCAN TOOL SHOWS 43 AND CALLS OUT CIRCUIT #3. AS IN ORIGNAL QUESTION, WHAT IS #3, ACTS LIKE CRANK SENSER BUT NOT SURE. SYSTEM DOES NOT HAVE CODE FOR EITHER CRANK OR CAM SENSOR PROBLEM SO IT ALL GOES BACK TO WHAT IS #3. THANKS, ALAN
Jun 17, 2008 at 3:28 PM
MERLIN2021
  • 17,250 POSTS
The code actuall reads #3 primary circuit, so that would be the plug wire is not producing enough spark, change the wires! Agood tune up must be in order...
Jun 17, 2008 at 5:14 PM
ALAN DETRICK
  • 4 POSTS
PLUG WIRES ARE NOT PRIMARY, THEY ARE SECONDARY CIRCUITS AND THEY WILL NOT MAKE A CAR GO FROM RUNNING FINE TO A COMPLEAT SHUT DOWN AT IDLE. FURTHER MORE THERE IS ONLY 3 SUB LINKS TO CODE 43. SO WHERE WOULD WIRES 4-6 SHOW UP? HERES SOMETHING ELSE IT HAS NEW WIRES AND COIL PACK. NOW WHAT DO YOU THINK?
Jun 17, 2008 at 5:59 PM
MERLIN2021
  • 17,250 POSTS
You need a Chysler DRB II to activate the coil circuits to test em, I will send the info to you, if coils are new, it must be one of the wires, test info on the way!
Jun 18, 2008 at 3:15 PM
ALAN DETRICK
  • 4 POSTS
THANK YOU FOR YOUR EXTRA EFFORT. LOOKING FORWARD TO ITEM YOU ARE SENDING. ALAN
Jun 18, 2008 at 6:35 PM
MERLIN2021
  • 17,250 POSTS
Let me know how you make out with it Al!
Jun 19, 2008 at 2:56 AM
VIPERTEK
  • 40 POSTS
you need a flow chart and manual. i have had computers do that same thing in same motors.. there are tests avaiable.. good luck i can provide thease charts and diagrams..
Jan 8, 2009 at 8:58 PM
