1991 Dodge Dynasty PROMBLE WITH TRANSMISSION
1991 DODGE DYNASTY
136,256 MILES • 6 CYL • FWD • AUTOMATIC
MICHAEL PR
I HAVE A 1991 DODGE DYNASTY BUT IHAVING PROMPLES WITH THE TRANSMISSION I JUST HAD IT REPAIR AND IT WAS RUNNIG FUNNY AND THE AT Solenoid WAS BURN OUT SO I CHANGE IT BUT NOW IT RUN GOOD FOR ABOUT 2 MIN DRINVING IT AND IT JUST WON'T PAST 10 MILES HRS AFTER I WAIT FOR A 10 MIN IT RUNS GOOD AGAING I WAS LOOKING IN THE INTERNET AND FOUND SOM PART AND I THINK THAT IT COLUD BE ONE OF THE IS Speed Sensors AND THE OTHER ONE IS Neutral Safety Switch BUT I JUST DON'T NOW BEACUSE I DON'T NOW THEIR FUCNTION CAN U PLEASE HELP ME FIND A SOLUTION
Jul 11, 2009 at 4:27 PM
TWINSRAM
  • 42 POSTS
If you replaced the transmission cylanoid and now it won't go into second gear, the belt inside the transmission is locking up. The transmission also has electronis built inside it and if you didn't remove the battery cable when you replace the cylanoid, it could have fried the internal electronics in the transmission. I had a '91 and the transmission wnet out. I put a new one in it and fried the internal mech. without knowing it and had to take the transmission back. they told me about the mech. and gave me a new transmission anyway (reluctantly). I made sure to disconnect all power and installed it. It worked fine. So either way, unfortunatly, you are PROBABLY going to have to replace the transmission. Good Luck, It took me awhile to do it on my garage floor.
Feb 24, 2010 at 3:36 PM
