1991 Dodge Dynasty Cruise control doesn't work.
1991 DODGE DYNASTY
FCHEATUM
Engine Mechanical problem
1991 Dodge Dynasty 6 cyl Front Wheel Drive Automatic 150+ miles
Any thoughts on the order of things to start checking to troubleshoot the cruise control not working? The fuses are fine.
Thanks
Apr 22, 2010 at 2:08 PM
CARADIODOC
  • 34,306 POSTS
Pull the brake pedal up with your toes when you press the set button. If it sets, the brake light switch is out of adjustment. If the horn also does not work, or the air bag light is on, suspect the clock spring under the steering wheel is breaking. It is a wound up ribbon cable that also has a circuit in it for the cruise control switches.
caradiodoc
Jun 1, 2010 at 2:25 AM
