1989 Dodge Dynasty 1989 Dynasty starves for fuel when hot
1989 DODGE DYNASTY
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRIAN1986
Car runs OK when cold. As it heats up, the car loses power and won't run, like it is out of gas. Had it looked at by 2 mechanics. Replaced fuel pump, fuel filter, plugs, plug wires, rotor and catalytic converter is good... Could it be Fuel Injector Pressure Regulator?
Feb 2, 2009 at 11:41 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You will need to get the fuel rail pressure tested to see if the regulator is working as it should, i would also be checking the coil when it heats up as it may be breaking down, it would be a good idea if you can get the car run on an oscilloscope hot to check the ignition system voltages, this will show up any problems with t he ignition.
mark (mhpautos)
Feb 3, 2009 at 2:10 AM
