Dodge Durango
DODGE DURANGO
JASONCL
I own a 2001 Dodge Durango with 98,000 miles on it in which the motor failed. I got a replacement from a salvage yard with 48,000 miles and had it installed but we are having a very hard time getting it to run smoothly. The motor is a 4.7 and we keep getting a cam shaft code like the timing is off. My mechanic says that if the timing is off that he would have to tear the motor down and start over to reset the timing. Is this true?
Feb 26, 2007 at 9:57 AM
2CARPRO JACK
  • 11,533 POSTS
If the engine wasnt taken apart then it wont need to be torn down. The engine needs to be put on #1 TDC to see where the distributor is pointing. The computer is seeing that the cam and crank are out of sync. worst case is the distributor would have to come out to be reinstalled correctly
Feb 27, 2007 at 7:33 AM
