battery drain
2006 DODGE DURANGO
TCSOTO
What should normal amp draw look like with amp meter connected in line to battery?
Oct 27, 2010 at 12:40 PM
About 15 milliamps down once the computers have gone to sleep. Here is a guide to help you test.
https://www.2carpros.com/articles/car-battery-dead-overnight
This guide will show you how to scan the CAn to see if any codes come up
https://youtu.be/InIlnsjOVFA
Oct 27, 2010 at 1:26 PM
OIDAVEY
  • 0 POST
I had this problem they replace the TIPM for $460.00
Jan 2, 2019 at 8:14 PM
GEORGEBURDEN
The alternator is good had an oil change but the oil light came on and it started to knock and rattle like it had no oil in it and then it shut off could it be a fuse or sensor
Jan 2, 2019 at 8:14 PM (Merged)
KHLOW2008
  • 41,814 POSTS
If oil pressure is not showing, the engine computer is programmed to turn engine off. You need to be checking the oil level and oil filter etc.
QUEEN_TIGERESS
my alternator is good but my battery wont stay charged whats could be the problem?
Check and test the computer controlled circuit of the alternator's field generation
BALEXA2874
2001 dodge durango
Battery was dead,trickle charged it but won't stay running
CARADIODOC
  • 34,306 POSTS
When the battery is disconnected or run dead, the Engine Computer loses its memory and has to relearn "minimum throttle" before it will know when it must be in charge of idle speed. To meet the conditions for the relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
caradiodoc
