2005 Dodge Durango Replace fuel line to to squirrels
2005 DODGE DURANGO
29,500 MILES • V8 • 2WD • AUTOMATIC
MOCKIE
I need to replace my fuel line from carb to gas tank due to squirrels
Jan 31, 2010 at 11:55 AM
CARADIODOC
  • 34,306 POSTS
You don't have a carburetor and I seriously doubt squirrels chewed through a steel line. What are the symptoms? The only place the fuel lines are rubber is from the steel lines to the engine, so the engine can rock on its rubber mounts, and between the steel lines and the gas tank. These are only a few feet long. Just replace any leaking sections, not the entire lines. You must use fuel injection hose. Your fuel system can have around 50 pounds of pressure. Carbureted cars from the 1970s had a small vacuum in the line from the tank to the fuel pump, and less than 5 psi in the line after the pump. Rubber fuel hose for that application will not withstand the pressures found in fuel injected cars.
caradiodoc
Feb 3, 2010 at 2:59 AM
