My headlights, cluster lights, wipers (non-int), dome lights and power locks will not work. I have looked at all the fuses in the PDC under the hood and in the fuse panel by the driver's side door and found nothing out of the ordinary. I have taken a test light to the associated fuse positions that I could find and the light lit up on the power side of the fuse except for the cluster light dimmer fuse (? - it was the 5A fuse in position 8/9). I do not have the tools to check the relays to see if they are bad but this seems like multiple relays if that is the problem. Is there a central timer module in which all these things are linked?...I see that phrase or item several times on a wiring diagram I am looking at. I'm stumped and don't know what to look for now and/or how to test it with the limited tools I have.
To make matters worse I am in Germany so it's getting dark and I will not be able to drive it tonight since the lights do not work. This also brings up the problem of parts since I will have to have everything shipped from the states. What do I need to look for so I can get it in the mail?
Mar 9, 2010 at 11:34 AM
