2003 Dodge Durango gas guage
2003 DODGE DURANGO
LOJO102
Electrical problem
2003 Dodge Durango V8 Four Wheel Drive Automatic 160k miles
when you turn on the key the guage goes to 7/8 full and dosent move until key off. also when you remove the gas cap it sucks in air and there is a popping niose in the tank for a few seconds.
Aug 2, 2009 at 7:37 PM
Is it sucking air in or releasing pressure? If releasing pressure, that is normal. If it is sucking the air in, there is a oneway vent (I believe it's on the rear of the fuel tank) that may not be allowing air to enter the tank as the fuel level drops.
Next, the fuel gauge can be a couple of things. First, and most common, the float gauge in the tank is damaged or the rheostat that sends a signal to the gauge is bad. If that is the problem, the fuel pump assembly will need replaced.
Aug 3, 2009 at 12:35 AM
