P0725--P0320 & P1299
2002 DODGE DURANGO
151,000 MILES • V8 • 4WD • AUTOMATIC
IR4OUNOKLA
Runs smooth for approximately 15 minutes then dies. Fuel injectors stay running and engine floods. Tach bounces after engine dies. When I run the codes they come up P0725--P0320 & P1299. I have already changed the crankshaft sensor. What do I need to do now?
Jul 26, 2010 at 5:34 PM
DOCFIXIT
  • 18,828 POSTS
Hi
Code P1299 is for vacuum leak and will shut down engine. Intake is plastic and prone to crack chek it and PCV and brake booster for leaks.Not sure what is meant by injectors keep running and flood engine How was this determined?
Let me know
Thanks for donate
Jul 27, 2010 at 12:55 PM
IR4OUNOKLA
When engine dies the injectors keep clicking until you turn the key off. When you turn the key back on the injectors continue to click. I have to hold the throttle wide open to get vehicle started and it has a strong gas smell.
Jul 31, 2010 at 8:52 PM
DOCFIXIT
  • 18,828 POSTS
Injector s are controlled by PCM they provide ground to open . If they stay clicking then PCM must be faulty or problem in wiring to Camshaft sensor and signaling PCM that there is cam rotation with engine off. Did you find any vacuum leaks? have you cleared codes ? and do they reset? P0725 no reference for that code it would be a Trans code
Aug 2, 2010 at 1:27 PM
BRYAN R
did you find the problem I have the same truck doing the same thing please HELP
Sep 2, 2010 at 6:34 PM
GINA WILSON
I have the exact same symptoms in 2002 dodge Dakota 4.7 please help
Nov 18, 2019 at 1:44 PM
This sounds like you have a shorted fuel injector causing the injector driver to go full on flooding the engine. To find the cylinder that is having an issue please remove all spark plugs (keep them in order) to look at the condition of each the bad cylinder will have a different looking plug. Here is a guide to help us:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Nov 21, 2019 at 2:29 PM
