2002 Dodge Durango engine surging
2002 DODGE DURANGO
140,000 MILES • V8 • 4WD • AUTOMATIC
02 durango 4.7 liter when you are going a steady seed with cruise or with out the rpm's will surge 100 to 500 rpm's. It is not shifting in and out of overdrive.
Dec 6, 2009 at 8:49 PM
Hi [email protected] and TY for the donation
Lets check below item to item and gest back asap when you find something that's not right
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Dec 6, 2009 at 10:27 PM
