2002 Dodge Durango Changing Transmission Fluid
2002 DODGE DURANGO
111,000 MILES • V8 • 4WD • AUTOMATIC
HARRBRA
I recently got some Amsoil transmission fluid. The guy who sold it to me gave me an unorthodox way of changing the fluid that I have yet to see online and wanted to double check before I did it. My Durango holds about 15 quarts of transmission fluid. He said to remove the outlet to the transmission cooler and attach a rubber hose to it, leading to an empty bucket. Then turn the truck on in park, and let the fluid pump into the bucket (straight out of the cooler) until the fluid stops, then immediately turn the truck off. While the truck is off, replace with the same amount of new fluid that came out of the cooler. Then turn the truck back on, and let more fluid pump into the bucket while at the same time replacing with new fluid until I have reached the designated transmission capacity (15 quarts). Then turn the truck off, reattach the outlet cooler line to the cooler, and I'd be good to go. I just wanted to verify if this was safe before I did it. The only moving part in a transmission I am aware of (in park) is the transmission pump. Will doing this method hurt the pump or anything else? Would this method ensure I get mostly Amsoil fluid in the transmission or would it cause a considerable mix of old and new fluid? What would you recommend?
Jun 20, 2009 at 12:34 AM
I never heard of that. THere is a system (which requires a machine) that flushes all of the old trans fluid out while new is going in. I would never recommend running the trans empty.
Also, your vehicle requires ATF+ 7176 or ATF+4. I can't remember which one exactly based on the year, but it will tell you on the dipstick. Make sure what you are using meets the requirements
Jul 17, 2009 at 5:03 PM
