2001 Dodge Durango radiator R & R
2001 DODGE DURANGO
100,000 MILES • V8 • 4WD • AUTOMATIC
COOKINITDOWN
could you please tell me step by step how to R & R a Radiator on my 2001 dodge durango.
Sep 7, 2010 at 11:33 AM
Removal and Installation REMOVAL WARNING: DO NOT REMOVE CYLINDER BLOCK DRAIN PLUGS OR LOOSEN RADIATOR DRAINCOCK WITH SYSTEM HOT AND UNDER PRESSURE. SERIOUS BURNS FROM COOLANT CAN OCCUR. Disconnect battery negative cable. Drain cooling system.
https://www.2carpros.com/forum/automotive_pictures/12900_r1_11.jpg
WARNING: CONSTANT TENSION HOSE CLAMPS ARE USED ON MOST COOLING SYSTEM HOSES. WHEN REMOVING OR INSTALLING, USE ONLY TOOLS DESIGNED FOR SERVICING THIS TYPE OF CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER 6094) . SNAP-ON CLAMP TOOL (NUMBER HPC-20) MAY BE USED FOR LARGER CLAMPS. ALWAYS WEAR SAFETY GLASSES WHEN SERVICING CONSTANT TENSION CLAMPS.
https://www.2carpros.com/forum/automotive_pictures/12900_r2_11.jpg
CAUTION: A number or letter is stamped into the tongue of constant tension clamps. If replacement is necessary, use only an original equipment clamp with matching number or letter. Remove hose clamps and hoses from radiator. Disconnect coolant reserve/overflow tank hose and washer bottle electrical connector and hose.
https://www.2carpros.com/forum/automotive_pictures/12900_r3_2.jpg
Remove upper fan shroud mounting screws Lift upper fan shroud assembly up and out of engine compartment.
https://www.2carpros.com/forum/automotive_pictures/12900_r4_2.jpg
Disconnect transmission oil cooler lines, (if equipped). Disconnect electric cooling fan motor connector.
https://www.2carpros.com/forum/automotive_pictures/12900_r5_2.jpg
Remove radiator upper mounting screws. Lift radiator upward and away from vehicle. Do not allow cooling fins of radiator to contact any other vehicle component. Radiator fin damage could result. INSTALLATION The radiator has two isolator pins on bottom of both tanks. These fit into alignment holes in radiator lower support. Position isolator pins into alignment holes in radiator lower support. Install and tighten radiator mounting bolts to 23 Nm (200 inch lbs.) . Install the transmission oil cooler lines, (if equipped). Connect fan motor electrical connector to harness connector. Position upper fan shroud onto lower fan shroud and radiator. Install retaining screws into shroud. Install radiator hoses. reconnect coolant reserve/overflow tank hose. Connect battery negative cable. Fill cooling system. Start and warm the engine. Check for leaks. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Sep 7, 2010 at 7:18 PM
