2001 Dodge Durango FAN CONTROL ONLY WORKS ON HIGH
2001 DODGE DURANGO
60,000 MILES • V8 • 4WD • AUTOMATIC
DEAN GUTHMILLER
i have dual controls for the front and rear fan, a/c. the rear control works fine. the front control will only work on high. is there an inline fuse? i have checked all the other fuses and they are ok or do i need to replace the control?
Dec 7, 2007 at 5:47 PM
FRANKIEFUEGO
  • 18 POSTS
You need to replace the blower resistor located under the passenger side of the dash (glovebox). I had the same problem and this fixed it.
Dec 25, 2007 at 11:02 AM
Yep , i agree here is the location of the blower motor resistor so you can change it out. Check out the images (below). Please let us know what happens.
Jul 17, 2024 at 5:32 PM
