2000 Dodge Durango WIPER FUSE
2000 DODGE DURANGO
54,000 MILES • V8 • 4WD • AUTOMATIC
HECTOR S
MY WIPERS STOPPED WORKING SUDDENLY. I CHECKED THE FUSE BOX UNDER THE HOOD AND COULD NOT FIND ANY DESIGNATED FOR THE WIPERS ONLY A RELAY WHICH I SWITCHED WITH ANOTHER KNOW WORKING RELAY AND STILL NO WIPER ACTION. IS THERE ANOTHER FUSE BOX INSIDE THE VEHICLE?
Dec 15, 2007 at 10:44 PM
CARLUCCIJA
  • 29 POSTS
yes there is another fuse box inside the car. I haven't been in a durango in some time but here are a few places to check. First place is when you open your drivers doorlook to the left on the dash facing outward. There might be a panel there labeled fuse box. If not there maybe on the opposite side on the passenger door. Moat cars though are under the dash control panel. Which you just lay under the steering wheel and you will see the fuse box. Sometimes the fuse box can be behind a removalable panel underneath also. Hope this helps you find it.
Dec 16, 2007 at 9:13 AM
HECTOR S
Thanks for your quick response. I found the box it was on the drivers side of the dash board. replace the fuse and wiping away. Thanks again you guys are great.
Dec 16, 2007 at 4:34 PM
