2000 Dodge Durango surge
2000 DODGE DURANGO
13,000 MILES • V8 • 2WD • AUTOMATIC
RIVERBOAT
engine surges at idle and hwy speeds up then down
Feb 11, 2009 at 2:26 PM
IT sounds like a throttle position sensor (TPS) of a Idle Air Control Valve (IAC). Is the check engine light on?
Feb 16, 2009 at 1:35 PM
RIVERBOAT
Joe; TPS ,MAPS, are new parts. Ck engine light does not come on.used code analizer-showed no codes ,then erased codes.
Feb 16, 2009 at 5:12 PM
Hi:
Have you checked fuel pump pressure? Is power normal other than the surge?
Feb 16, 2009 at 5:34 PM
RIVERBOAT
yes I have,and presure is normal
Feb 16, 2009 at 5:38 PM
If the electrical end is good and fuel pressure is good, the only things left are a vacuum leak or catylatic converter may be plugging. Have you checked for these problems?
Feb 16, 2009 at 6:38 PM
