[quote:3d3686c1cc="jlsandr22"]Other Category problem
2000 Dodge Durango V8 Four Wheel Drive Automatic 143000 miles
I am having trouble finding what I have been told is a radiator filler neck. It is a simple assembly that looks like at T and the radiator pressure cap fits on the top. It connects the upper and lower radiator hose. Can you possibly give me a part number or some technical name for the part so the dealership can help me figure out what I need.[/quote:3d3686c1cc]
The part no. is 902-305 at advance auto and 6002747 at O'riley. Unfortunately the problem with this replacement part is that it will likely not hold when under pressure. You’re best bet is to buy the entire upper hose assembly from a Chrysler dealership. You can get it for $50 +/-. The assembly comes with the filler valve, cap, hose from motor to cap and hose from cap to radiator. Replacing the entire assembly costs less then buying the parts separately and you don’t have to worry about it failing when the pressure builds up.
I know this from experience. Save your money and buy the assembly from a dealership!
Sep 21, 2009 at 8:41 AM
