hi Jacobandnickolas,
I've bled the system three times and still have the same problem. Also changed all the o-ring seals several times along with new fluid and replaced high pressure line and return line. Second new pump today, same thing. Start the vehicle, turn the wheels and the fluid bubbles and foams out of the reservoir, growls very loud. If I put the cap on when this happens it will over pressure so bad that it will blow fluid out of the cap seal. I'm wondering if it might be a bad rack??
Thank You very much for your help.
Mar 16, 2010 at 9:45 PM
