2000 Dodge Durango Clicking noise while moving slow
2000 DODGE DURANGO
149,567 MILES • V8 • 4WD • AUTOMATIC
A_T_DIAMOND
I just started to notice a clicking noise when I back up in reverse it will do it 1 maybe 2 times as I back out of the drive way or car parking spot. Then as I pull away I here a clicking noise as I get up to about 20 mph once I'm over 30 mph it either goes away or the road noise covers it up. I've noticed recently an oily substance in the driveway, I've looked underneath but can't figure out where it is coming from, looks possibly around the U-joint or axle area, NOT A MECHANIC so I have no idea, I've heard it could be the lifters? I've heard it could be the rear end? Then I've got one other issue, over heats as I drive up logging roads in the mountains once at speed the engine cools down, but driving slow up hill or if going through the bank drive through temp gauge starts to rise....
Nov 1, 2010 at 9:40 PM
The overheating sounds like the fan clutch needs replaced. It should make the fan spin faster at low speeds when there is not enough air circulation to cool the radiator.
As far as the leak, is it near the rear axle or the transfer case? To me it sounds like a U-joint, but that wouldn't cause a leak unless it has caused damage to a seal.
Nov 5, 2010 at 1:46 PM
