Heater blowing luke warm air?
2000 DODGE DURANGO
134,000 MILES • V8 • 4WD • AUTOMATIC
ANGI76
My durango just recently started only blowing out luke warm air. The temp gauge shows the truck is at normal engine temp. My question is what is likely to be the cause of this?
Jan 5, 2010 at 2:04 PM
SERVICE WRITER
  • 9,123 POSTS
The first thing I would check is the coolant level. IT must be full.
IF full, leave blower off and bring to operating temp.,
Then turn on blower to high, Is it warmer and then quickly cools off? PArtially plugged heater core.
feel the heater hoses when at operating temp. Are both hot?
This guide can help
https://www.2carpros.com/articles/car-heater-not-working
If it is slow to come to temperature and your fuel mileage is worse, the thermostat may be defective.
Jan 5, 2010 at 8:03 PM
STEPHANELOYER
2000 dodge durango r/t 5.9l i changed heater core,water pump,thermostat,all hoses and i burp the system with a spill free funnel let the truck run for almost a hrs,temp gauge still goes only to a 1/4 of the way and still have only luke warm air.
could someone help me out whit this problem please.
Steph.
Aug 6, 2020 at 10:59 AM (Merged)
HMAC300
  • 48,601 POSTS
check to see if your actuators on your heater are working correctly. one controls air temp and another movement.pic enclosed of blend door
STEPHANELOYER
ok thanks i will try that and let you know.
BRADBRIDGET
i have no heat?
Check and test the thermostat and heater core if its clogged.
This guide should help us.
BRADBRIDGET
has new thermostat, the head gasket has blown filling the heater core with exhaust gases FYI great guide helped me find the problem.
25HERKY
My wife hit a deer last winter, and ran the car just about dry. I fixed everything. It runs just fine, temp is just fine. but no heat and with this last winter it got just a little cold driving it to work.What is up
BLACKOP555
  • 10,386 POSTS
with the vehicle warm and idling pop the hood and feel the heater core hoses.
post back what you find, feel them directly at the firewall.
is one of the hoses hot and one cold?
both warm?
both hot?
neither hot?
one warm and one cold?
KRISTENK
My Dodge Durango's heat has not been working since last winter. The blower works just fine, but the air is cold no matter what the engine temp. I usually work on the vehicle myself, but now that it is freezing outside, I brought it in to a local shop. They told me that I needed a new water pump. I replaced the water pump approx. a year and a half ago. Is it possible that the water pump is the problem? I was thinking it would be the thermo or heater core. Thanks so much!
SERVICE WRITER
  • 9,123 POSTS
Typically if it is a thermostat, you'll have a much longer warm up period that could be bad enough to set the CEL. After a while you should get some heat. The gauge would also be showing cold for the majority of the time.
Low coolant can do this.
A plugged heater core can do this.
Did they check for the temperature of the hoses going in and coming out of it?
Is the pump leaking or are they assumming the impellers are worn causing a lack of circulation?
IF the coolant is full and the engine is at operating temp. Then by reving the motor to increase flow, some heat should come out I would expect if it is the waterpump.
I would ask them that if it didn't fix it, will they absorb the cost?
Waterpumps often have a lifetime warranty if it is a new one.
UPSTATEDODGE2000
all the blowers work...antifreeze is full...the a/c works in summer.and so does the heat...but heat doesn't work now that it's wintertime...and it's been well below zero here in Upstate NY...I have let it run for 2+ hours in my driveway, after driving through town to "warm it up"....nothing...still cold...I don't have a lot of money to have the dash pulled apart by one of the dealers around here who rip people off (known fact locally)...is there something I can try FIRST to see if the problem is a small quick fix before just shelling out for another vehicle...I really love my truck....if there is nothing small to try first...I may just have to buy the small portable car heater/defroster I saw in a catalog ..LOL.....thanks for any help you can give me....P.S. I would like to do it myself, as I have been trying to be totally independent from men as they don't think a woman can fix her own truck....I want to rove them so totally wrong..... :-) thanks again..copperdragon
CARADIODOC
  • 34,307 POSTS
Very interesting. Here in the middle of Wisconsin we have a bunch of very reputable new-car dealers, and two well-known crooks. One is the local Chevy dealer and one is an independent repair shop. Those two stay in business by constantly looking for new customers. I worked for a very nice family that owns four Chrysler dealerships. We traded service manuals with the GMC dealer down the road and what used to be a pretty nice Ford dealership until the crook bought them out. We had a nice import dealer too. We did a lot or repairs on each others trade-in cars.
Also, three of my top students were girls, and the guys had a lot of respect for them. It's common around here to find lady mechanics.
For your problem, start by feeling the radiator hose after the engine is warmed up. It should be too hot to hold onto for very long. If it is not, suspect the thermostat. If it is, feel the two heater hoses. If they're cool, the heater core could be plugged, but first look for a water control valve that isn't opening. If the heater core is plugged, those can usually be cleared by running water through them from a garden hose.
UPSTATEDODGE2000
radiator hose is hot...not sure where the heater hoses are...and where the control valve would be...and thank you for answering..and giving me some hope that women are doing great in the field of mechanics...I have also wondered if the flow control valve lever is in the off position...possibly after the flush and refill it may have been left off...Where do I find that? I have looked at many diagrams but cant seem to put my fingers on it...I would like to try everything that I can do before really having to take it to spend 7-9 hours having someone pull the dash apart only to find it was a very simple fix....the next thing I will try is the thermostat if the control lever isnt the problem...and then the heater core...Thank you again for your help..I truly appreciate it....copperdragon
UPSTATEDODGE2000
heater hoses are warm...the two that come from engine block through to the inside under dash...my next try is the control valve..THATS the one I can't get a good image of from the internet
CARADIODOC
  • 34,307 POSTS
You may not have a water valve, but if you do, it's inline with one of the heater hoses. Years ago they had a cable running to them from the controls on the dash. Today they're run by a vacuum motor and will have a small vacuum hose going to it.
If the heater hoses are just as hot as the radiator hose, coolant is circulating through the heater core, and the temperature door in the heater box is suspect. Look for a cable from the temperature lever that is slipping on the door's lever, or a vacuum hose that is disconnected or leaking.
The temperature door can be rusted in the "cold" position too. That's when a cable-operated lever seems to work, but actually where that cable connects to the door's lever is supposed to slide somewhat freely. That is the self-adjusting feature, but when the door is stuck, the cable slides back and forth in the adjustment without moving the door. This problem usually shows up in winter after the door has been in the "cold" position all summer and had a chance for the metal hinge pin to rust.
If the heater hoses are not as hot as the radiator hose, the heater core could be plugged. To clear it, remove one of the heater hoses from the engine, and the radiator cap, then run water into the hose from a garden hose. If the water doesn't flow freely after a few seconds, it may be necessary to remove the other hose and run the water the other way.
MGOOSE
  • 4 POSTS
2000 dodge durango hear not hot
WRENCHTECH
  • 20,761 POSTS
With the engine at full operating temp, locate the 2 heater hoses where they go into the firewall and feel them to see if they are both hot to the touch. If not too hot to hold, then you have to look at the actual engine temp and if that is up, if it is, then your looking at a restricted heater core.
If you find that they are both too hot to hold, then the heat in that vehicle is controlled by a blend door that regulates heated air flow. it is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
If they are both not too hot to hold on to, then you either have a restricted heater core or the system is not completely full and getting air pockets for some reason.
JSSMURF
The truck overheated on me the other day, I dicovered the thermostat was bad (boiled it and it didn't open) and I also replaced the top radiator hose. The water pump is a year and a couple months old. Now the heater blows cold and the engine still heats up past the 210 mark on the guage. The top radiator hose does not get hot, but I took the new thermostat back out and heated it untill it opens seems to be about 190 deg. Any suggestions?
MERLIN2021
  • 17,250 POSTS
Any visible steam near the heads? Or white smoke out the tailpipe? If so get a block test kit, they run about 50.00, this will check for a cracked head or blown head gasket...Also make sure the tstat is in right, the copper spring should point to block!
no heat coming into car , new water pump,new heater coil,new plower fan ,new thermostat, hose peplaced,no leaks in car,no leaks showing undrhood or on grown.
sounds like a mode door issue in the truck.
when you did the heater core, did you hook everything back up??
JDL
  • 16,098 POSTS
Is any air coming into the vehicle? Can you hear the blower motor run? I saw what you replaced, didn't see any testing. If blower motor is running but no air coming out, check temp door and actuators, under the dash.
DAVIDSTACEY
Why don't I get much heat it stays Luke warm it has a brand new radiator and thermostat
It could be a couple things. First, with the engine at normal operating temp and the heater on high, feel both heater core hoses. Both should be hot. If only one is hot and the other slightly warm, flush the heater core. If both are hot, check the blend air door actuator for operation.
RAPALLO2214
My Durango does not blow any hot air at all. The heater hoses are hot to the touch and there are no leaks. I've flushed the system, back flushed, changed thermostat. It doesn't overheat, nothing wrong with the truck, no engine lights or codes. I've been told it may be the blend door actuator or something that diverts the air. Any help please?
Thanks,
Michael
HMAC300
  • 48,601 POSTS
check for a broken temp control cable it can be broken at either end and not opening door so heat will work. also the heater may have a vacuum motor to open door so check for vacuum at door as well as a vacuum leak . we have no pics of this sorry
