@ 6 months ago trans would momentarily go into gear then not go. Had to wait 30-120 sec for trans to engage into gear. Would go normally for a few seconds then go out of gear again. Changed fluid w/ atf 4 and filter. Worked ok @ 6 mo. Now trans will not go into gear at all. Changed filter and oil again and prob remains. Filled unit to full mark but noticed the trans oil level is not dropping as it did before as oil is circulated thru trans. Oil level stays static. When shifting thru gears and reverse rpm is not affected as it would b when trans engages.
Aug 11, 2010 at 7:19 PM
