1999 Dodge Durango ticking driver side
1999 DODGE DURANGO
72,000 MILES • V8 • 4WD • AUTOMATIC
SHELBY-DO-IT-YOURSELF
Ive had this problem for awhile now. I'm thinking its a rocker arm. but it ticks with the rpms and you can really hear it from inside on the driver side. The rattle/tick moves with the rpms. i have a supercharger on top of the motor so itll be a job if i have to replace something like a rocker. any suggestions? also the truck will idle fine then out of no where it will start sucking air and becomes loud. Then if i let it go for to long the truck wants to slowly stall out. after i give it some gas it idles fine. could it be a tps, iac? everything on the truck is aftermarket, well most of it. any suggestions would be nice. But my main concern is the ticking/rattling. Also my heat knob is all the way turn to high heat and its ice cold a/c. What would cause that?
Oct 28, 2010 at 6:23 PM
AC - Check the blend air door
Idle - Check the idle air control valve
Ticking - sounds like a collapsed lifter or a loose rocker arm. The only thing you can do is take it apart and check to see where the problem is.
Let me know what you find.
Nov 5, 2010 at 1:51 PM
