1999 Dodge Durango SPEEDOMETER INOP
1999 DODGE DURANGO
95,865 MILES • V8 • 4WD • AUTOMATIC
TBOW
I HAVE REPAIRED REAR BRAKE LINES FROM MASTER CYLINDER TO THE REAR WHEEL CYLINDERS. AT THE SAME TIME THE BRAKE LINES STARTED LEAKING FROM RUSTING THROUGH THE SPEEDOMETER QUITE WORKING AND A CODE P0500 WAS STORED. I HAVE REPLACED THE REAR AXLE SENSOR BUT IT DID NOT FIX THE SPEEDOMETER. THE CUSTOMER THINKS THE SPEEDOMETER IS ASSOCIATED WITH THE BRAKE LINES LEAKING, BUT UNTIL I FIX THE SPEEDOMETER THE ABS LAMP AND BRAKE LAMP WILL NOT GO OUT. HAS ANYONE RUN INTO THIS SITUATION. PLEASE HELP.
Sep 20, 2010 at 7:38 PM
TBOW
4 WHEEL DRIVE---P0500 CODE STORED
Sep 20, 2010 at 9:39 PM
