1999 Dodge Durango LIGHT ON SAYS "CHECK GAUGES"
1999 DODGE DURANGO
LOWILLIAMS
Electrical problem
1999 Dodge Durango V8 Four Wheel Drive Automatic
THERE IS A "CHECK GAUGES" LIGHT ON. DOESN'T SAY "CHECK ENGINE" COULD THIS BE A FUSE?
Jul 29, 2010 at 2:17 PM
HMAC300
  • 48,601 POSTS
if it's on and your gages read ok , then it may be a bad ground or relay. It usually goes on when you get low oil pressure, high coolant temp or maybe the alternator isn't charging.....
Aug 3, 2010 at 5:43 PM
