1999 Dodge Durango
1999 DODGE DURANGO
156,000 MILES • V8 • 4WD • AUTOMATIC
BUILDERBOB1775
I just bought the truck and found out it had a bad engine so i put a used engine in and cant get it to start.I dont have spark.I have power at my coil and injectors only when it dose the initial 2 second injector prime when the key is turned on. I have nothing at ether place while cranking. I have been fixing cars for 18 years and i am stumped. The only codes are batt temp sensor to much voltage and engine coolant temp sensor to much voltage
Feb 9, 2008 at 10:28 PM
BLACKOP555
  • 10,386 POSTS
chances are you have a bad crank position sensor, coil or a ignition module. test the crank position sensor at its leads for the proper resistance, which i dont know. if that is good then check for the coils resistance and if that is good then you have a bad ign. module.
Feb 10, 2008 at 7:22 AM
