Rear turn signal stops flashing when brake pedal is pressed
1999 DODGE DURANGO
CLAYHAAN
Why does the left hand rear turn signal stop flashing when i step on the brake pedal?
Mar 11, 2010 at 4:29 PM
CARADIODOC
  • 34,306 POSTS
Watch the lights while a helper presses the brake pedal and you'll see unusual things happening. Suspect a bad ground. After the current goes through one bulb, if it can't get to ground, it will find a way there through another bulb. When that second bulb is turned on, voltage appears where the first one had found a ground. When voltage appears on both sides of the first bulb, it turns off.
caradiodoc
Mar 11, 2010 at 8:16 PM
