1998 Dodge Durango Location of low side port on A/C system?
1998 DODGE DURANGO
130,000 MILES • V8 • 4WD • AUTOMATIC
KAPARSONS
First time working with my A/C on my 98 Durango. I need to hook the hose up to the LOW SIDE PORT, but I'm not sure where it is (or which is HI and which is LOW). The lines aren't color coded, the caps aren't marked. Any help would be greatly appreciated.
May 29, 2008 at 2:24 PM
MERLIN2021
  • 17,250 POSTS
If you have located the two ports the low side is the larger diameter port, and if you are recharging, you cant hook up wrong...
May 29, 2008 at 2:31 PM
KAPARSONS
I think I located both ports. One is directly on top of the compressor, center of the engine compartment. The other is on the left, front section, near the radiator. Does this sound right? I think the one in the center is the low port...looks like its the one that fits ;)
Thanks for you help!
Ken
May 29, 2008 at 2:39 PM
MERLIN2021
  • 17,250 POSTS
Sounds good...
May 29, 2008 at 4:10 PM
