1998 Dodge Durango just bought 3 weeks ago
1998 DODGE DURANGO
145,000 MILES • V8 • 4WD • AUTOMATIC
NIKIYIA
i was driving down the highway and all the sudden my 'check gauges' light came on.i looked down & had lost all oil pressure& my car overheated before i could get off. now i start my car and the engine makes a terrible knocking sound. also i still have no oil pressure.what can this be & how much to fix it?
Mar 23, 2010 at 1:43 PM
CARADIODOC
  • 34,306 POSTS
A loud knocking sound is commonly a worn or "spun" connecting rod bearing. Typically the engine needs to be rebuilt and the cause of the loss of oil pressure determined. If the oil level is full, the spun bearing would cause low or pulsing oil pressure. No oil in the engine, or a plugged or broken oil pump can lead to the spun bearing(s). Either one can cause the other.
This should be listened to and inspected by a professional since there are other causes of noises.
You'll need to get estimates for an engine rebuild or used engine. I bought a Caravan with this problem. Parts, including a used crankshaft and a fairly expensive gasket set cost $300.00. Students took care of the labor to remove and install the engine and to perform the machine work, but this was a six-week project. To pay a shop to do the work in a timely manner, expect around $2,000 to $3,000, possibly less if they install a used engine.
caradiodoc
Mar 23, 2010 at 3:35 PM
