1998 Dodge Durango Hazards
1998 DODGE DURANGO
150,000 MILES • V8 • 4WD • AUTOMATIC
CASTLE9704
I have recently replaced the multifunction switch, clock spring, and 4 way flasher fuse. My hazards will not work. With the flasher switched on the blinkers will not work. When I was replacing the multifunction switch (before I actual replaced the part) the flashers worked briefly. What do I need to check next? There does not seem to be any wires melted around the steering wheel.
Jan 15, 2010 at 11:08 PM
CARADIODOC
  • 34,306 POSTS
Now replace the most likely culprit, the electronic flasher assembly. It's plugged in on the left side of the dash.
By "blinkers", do you mean turn signals or 4-way hazard flasher?
caradiodoc
May 26, 2017 at 7:34 PM
